Hello all - I am hoping someone can give me a few pointers. There was, at one point in time),a wood burning stove in the middle of our very small living room (as witnessed by the pipe hole in the rear of the picture attached). When we bought the house, it was already replaced by a 1980's gas insert. The ugly old thing was broken from the get go and the house now has central heat. In other words, the need for heating is secondary. As such, we removed the insert and found a really nice antique radiant heater. We hooked it up and tested it, everything works fantastically well. It is absolutely beautiful when on. So here are my questions:
1. Does this need to be vented? Assuming so, what would be your suggestions on how to do so? We can easily vent directly outside, but I am unsure what type of fan assembly would be appropriate.
2. I plan to build or buy a fire box since the fake surround is all wood. Should I line a frame with cement board and then brick or tile over that?
3. Assuming yes to both of these questions, is there a recommendation on where I should plan install a venting fan? I would prefer for it not to be visible.
One Last point, we have a carbon monoxide detector located next to the fireplace and we do not intent to leave it on without supervision. BUT if anyone has suggestions on how to retrofit any potential safety devices, I am all ears.
Thanks!
Beckie
Thanks!
Beckie
