The steel looks fatigued on the push plates. Does it run?
Does it run in the cold?
Do you need ether?
It looks non-girly.
![[Hearth.com] Any other big splitters out there? [Hearth.com] Any other big splitters out there?](https://www.hearth.com/talk/data/attachments/172/172499-06b583700c6db09381dd3d7f7d1d392f.jpg?hash=4UnQp20d3F)
Just having fun...
Just take note of what the stuff is. Most pumps for the applications you mentioned are not two stage pumps and require big HP to pull to any typical log splitter pressure.a hydraulic pump,
I see. This is a pump off a 7 yard dump/plow truck. So, you're saying a 5 HP engine may not be enough to operate this pump? It makes sense. I hadn't really thought of it.Just take note of what the stuff is. Most pumps for the applications you mentioned are not two stage pumps and require big HP to pull to any typical log splitter pressure.
Highly likely that it falls into one of two categories...I see. This is a pump off a 7 yard dump/plow truck. So, you're saying a 5 HP engine may not be enough to operate this pump? It makes sense. I hadn't really thought of it.
