Anyone have a Woodstock Keystone installed in a corner?
BlueR
8
North Carolina Mountains
Just wondering if anyone has a Woodstock keystone installed in a corner.. our current woodstove is installed in a corner and I want to see how one looks so I can have a better idea of hearth lengths etc.. I’ve seen the diagram in the instruction manual but actual install pics will be good for reference.. ours won’t be installed for another few weeks..
Thanks in advance..
To install in a corner one must take into account that it is a side-loader. That means there needs to be at least 16" of hearth on the loading side. With high side clearances this means a large hearth. If this is ok, then it can work out. See the manual for corner installation requirements.
Minimum hearth size in a corner installation must be 54”x54” (with the front corner cut off). NOTE: On a hearth of minimum size, the stove will not be centered left to right, but will meet the minimum required clearances.
I’ve seen the manual description.. I’ve also see other side loading stoves installed in a corner with heat shield 12” from the stove corners.. so it should work but I was looking to see if anyone else has done it.. thanks :)
I have one installed in a corner. The side loading has not been an issue for me. I may be short a couple inches on the R rear corner clearance but have not seen this to be a problem.
Edit: I do have both the bottom and rear heat shields installed.
[Hearth.com] Anyone have a  Woodstock Keystone installed in a corner?
Reactions: Todd
Yes, this is viable when the manual indicates it is permissible, which Woodstock does.
