Kind of sounds like something I don't need.It's not like the self-start. This is a servo driven draft control with computer logic. I suspect it will be an option or it will put Englander up in the Lopi cost bracket.
But you'll all put blind faith in the stat on your oil furance, gas furance or electric furance....
I think this is not like the cat t-stats (mechanical coils) but a servo-driven draft control unit with some programmed logic, sensors, etc. as BG mentioned - can someone verify / clarify that? - if so then maybe there's more to break down?
True, but shutting off a gas valve or oil burner or an electric disconnect with a fail safe high limit switch that is basically mechanical, i. e. a thermo disc is fairly simple and fail safe. Shutting off burning chunks of wood would be a little more difficult I imagine.But you'll all put blind faith in the stat on your oil furance, gas furance or electric furance....
