Anyone do it? Regrets? Likes?. I think about it every year around this time when my back is stiff from working firewood.
It sure beats electricity!
All of the noise is my problem.
I’m not sure what stove you had before, but dang! 2 wheel barrel loads a day? I don’t burn that much with both my stoves going.It was lots easier bringing up bags of pellets instead of couple wheel barrels of wood up daily.
What is the cost of propane or natural gas where you are? That's even easier: no hauling anything, thermostatic control... (yes I know, some high end pellet stoves have thermostats but most don't) Fossil fuels and all tho, sounds like you like the idea of wood, but don't forget those options.Anyone do it? Regrets? Likes?. I think about it every year around this time when my back is stiff from working firewood.
A heat pump is much quieter and if an efficient model it costs less to operate in our area.
I’ve had my pellet stove for one year and have had a couple issues come up that were ultimately covered by warranty. I tried fixing these issues myself first but then called on warranty. Some pellet stoves can have small clearances to combustible walls. I believe mine called for 4 inches and mine is installed in corner of room. I asked for a couple extra inches out from wall than the minimum clearance. Doing this really helps when maintenance needed.Having serviced a few pellet stoves the question is which is more likely to break-down? If pellet stoves were as robust as furnaces that would be an easy answer, but they are not. I have had to replace snap disks frequently, a control module and on one Enviro, the damn air air vacuum tap kept clogging, and it was not in an easy place to service. All this was with stoves 2-5 yrs old. And that doesn't include frequent ash dumping, window cleanings, etc.. Folks I know with heat pumps are not dealing with these issues. Nor have we. Our heat pump went in in 2006 and the only thing I have serviced is the air filter.
