I have heard about this but I would like to know where you or other people heard about this? I've seen this on chimney sweep websites but i find it mostly to sell a labor
Ok. So, your mortar is compromised. Creosote is getting into the cracks. How do you get into the cracks to remove it? It’ll continue to seep into the chimney itself. On some older houses, you can see it seeping through the outside of the chimney. If it were to ignite and catch on the outside, there is nothing stopping it from igniting your house. A liner will stop this.
Here’s a pic off Reddit. I never thought to take pics when I saw it. I’ve seen it much worse though.
There is more than 50 inch of pipes connected to the stove before the smoke enters in the flue and then the flue is 20ft height from the connection to the top. I guess due to the long commute the temperature has time to decrease.
I also don't do huge and super hot fires. Only when I start it or maybe once a day
We can only advise you. Multiple people have told you that it is a huge safety hazard for you, your family and your house operating that flue in its current condition. Common sense should be common in this situation. If you choose to ignore it and something happens that’s on you 🤷🏻♂️
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
