Still on. Takes effect first day of next year.Is that still on the books? I thought they dropped it. But I could absolutely be wrong
I hope they drop it.
What do you mean by "cleaner"? Fewer particulates? Yes. But that is not the same thing as fewer new carbon molecules being released into the atmosphere.Natural gas burns cleaner than wood.
Assuming you aren't cutting down living trees for firewood, there's no need to plant new trees in order to be carbon neutral. The carbon contained in the dead tree you are burning would have been released as the wood decayed anyway. The same cannot be said for natural gas, which burns carbon that was trapped deep within the Earth and would not have been released anyway.True. I think he was talking about carbon neutrality. One could argue that wood burning is carbon neutral. It is if you plant enough new trees to offset your stove's carbon footprint. I'd argue the same is true for any carbon emissions. Planting new trees could go a long way to addressing global warming but it would take billions of trees.
Well some of it would be released into the atmosphere some would be injested by bugs and some would end up in the ground. Its still about as close to carbon neutral as it gets. But it is not.Assuming you aren't cutting down living trees for firewood, there's no need to plant new trees in order to be carbon neutral. The carbon contained in the dead tree you are burning would have been released as the wood decayed anyway. The same cannot be said for natural gas, which burns carbon that was trapped deep within the Earth and would not have been released anyway.
Fair enough.Well some of it would be released into the atmosphere some would be injested by bugs and some would end up in the ground. Its still about as close to carbon neutral as it gets. But it is not.
Honestly there is really very little widespread push against woodstoves. There are some areas prone to air inversions where the smoke just lays there and is pretty unpleasant. Those are generally the areas with no burn days and stricter regulations. And anyone who has lived next to someone who smolders wet wood all day will eventually get annoyed. Nothing we can do about the air inversion areas. But proper burning techniques with good fuel will avoid most problems even with old stoves.Up here in the mountains of TN I can't see it going away in my lifetime. Many people heat with wood as the primary if not only heat source. The Fatboy propane tank I see couldn't do much in a pinch. This time of year I see many piles of pine trunks in a yard being processed, it's just too easy and cheap.
I have more wood to burn than I will in my lifetime and lots more on the way. There are 100s of saplings each year I have to deal with around the house. Since these pines are just waiting to fall, not if but when, I get rid of them close to the place but let them go further out in the woods.
I can understand the problems y'all have with the Ken and Karens in some areas. They run on emotions rather than reason. It was said and is true, one ice storm will make a lot of people rethink the total dependence on the electrical grid. It's just sad it'll be such a sharp lesson to learn.
Definitely. My son, when looking at a house, doesn't consider what he wants or considers attractive. He looks at what sells most easily. Of course that too can be a guessing game. But he seems to have a good sense of it. If there were widespread demand for wood stoves, he'd put them in. That he replaces or rips them out tells me he doesn't think most people want them these days.Yes, our geography does lead to occasional wood burning bans in some years. They are a good idea when there is a major temperature inversion with no air flow between mountain ranges. FWIW, we didn't have one last year.
CA has a lot of air quality issues. Most of the bans there apply to urban areas, namely in the LA and SF region. Flippers and real estate agents have very different objectives from a homeowner. They don't pay the future utility bills.
They don’t want a barn for their buggy eitherThat he replaces or rips them out tells me he doesn't think most people want them these days.
You've really got your bases covered. We have several heating systems too. Primarily, we use our heat pumps (two separate mini-split systems, a total of five heads). One big one for the main part of the house, an intermediate sized one for the master suite and smaller ones for the bedrooms and office. We use our wood stove for backup. Also have a gas fireplace that runs on propane that sits in a 500 gallon buried tank and gets refilled once a year. We use that for the hot water heater, the dryer, the kitchen range and the fireplace. We also have a radiant heating system that I keep shut down because it's really inefficient. I suppose all the space heaters sitting in the garage are our last line of defense against the cold.Coming for rural people's wood stoves will be as divisive as guns, in my opinion. I know there are certain cities (Montreal might have tried to move on them), but I think you are messing with people's independence by trying to do this. If I lived in the northeast, I would never rely on heat pumps as my primary source. Maine was pushing hard to drive people away from oil, gas and wood by offering rebates for heat pumps. We are due for a severe cold winter and with the electric grid stretched thin, I would not want to be reliant on a heat pump only. In my mid 50's.. I buy my processed wood now but do it for comfort and security. We have 4 sources of heat in the house that could keep us from freezing. Wood, Pellet, Oil boiler and heat pump.
Hit it on the head there. The 'powers that be' want everyone to be dependent on the system. A dependent people are a controllable people. Electric heat = dependence. Electric transportation = dependence. Fiat currency = dependence. Convuluted grocery supply chains = dependence.you are messing with people's independence by trying to do this.
We probably shouldn't get into politics.Hit it on the head there. The 'powers that be' want everyone to be dependent on the system. A dependent people are a controllable people. Electric heat = dependence. Electric transportation = dependence. Fiat currency = dependence. Convuluted grocery supply chains = dependence.
The list goes on.
I'm not even out of 1st gear my man.We probably shouldn't get into politics.
No politics please, they are not allowed here.I'm not even out of 1st gear my man.
And your posts will be deleted if they get to political. That was fine but I won't allow much furtherI'm not even out of 1st gear my man.
