Our oil use is for our hot water almost exclusively - interesting that it is about 25% of our total home energy use which seems to be pretty much in line with averages I've read although I can't cite one off hand.
. I don't consider myself a miser with electric use. All my satellite equipment stays on standby. Porch light stays on 24/7 and a couple other lights stay on all night. Computer stays on 24/7 but I shut the CRT monitor off. I play music and run stereos and amps. Often I will run a space heater at my feet when sitting at the computer, or keep one going if I'm gonna be gone for a really cold weekend so the pipes don't freeze. Which is all included in the electric use. And I might go through less wood this winter with nobody feeding the fire all day.Is that the 1050 ft2 chalet?
I'm sorry, I didn't include the link in my original post:
http://www.eia.gov/consumption/residential/reports/2009/consumption-down.cfm#fig-4
It looks like that's the energy consumed by a house over the course of a year, neglecting cost.
We're all electric and located in central NY (about 7200 annual HDD). Last 12 mo's electric use total was
12627 kwh or 43.1 MBtu. We heat the whole house (1400 sq. ft, 170 year old house) and set the tstat to 67 without any setbacks, and air condition to 72 as needed. We cheat, though...GSHP. To the OP, when I used to heat primarily with a wood stove located in my cellar, the btu #s were skewed higher using wood (over our existing oil furnace at the time). I figured this was due to the inefficiencies of the stove and having the wood stove in the cellar, more than anything.
But lest you think I am some sort of green snob, I put in an ASHP for the old fashioned reason that it was cheaper than than any other option over the 10 yr timeframe, even when a wind power surcharge is added. The rest is green gravy.
10,429 KWH Oct 2011
12,400 KWH Oct 2012 after adding inground pool with heat pump $2285.64 42.31 MBtu??
Electric oven, stove, dryer and central a/c
850-950 gallons oil $3300-3600 ouch....before installation of wood stove
Guesstimating 5 cords wood? Hoping for less but our stove seems to be eating wood.
Did I miss how to figure out MBtu? I did find one calculator for KW.
Oil is 139,000 BTU/gal, so 900 gals is = 125 MBTU
Hardwood is ~23 MBTU/cord, so that is 115 MBTU
You total would now appear to be ~155 MBTU.
It seems unlikely that you dropped your MBTU when you switched fuels. Either your 5 cord estimate is short, or you reduced your heating load when you you switched. Or your oil boiler is from the stone age.
I am doing a test tonight of using the electric radiator backups for the first time to see if they can hold the place around 68 to 70. Watching the whole house power monitor is painful. 35 outside and kicking an average of 3 kwh per hour since noon. Probably gonna be a fire in one of the wood stoves tomorrow.
OK MBtu is not an efficiency thing, it is how many BTU's of energy my home requires? I was thinking the lower number the better?
2400 sqft, 5000 HDD
Comes to 7BTU/sqft/HDD for heating, considering the inefficiency of wood heat and a 30 year old house, not too bad.
This is my first heating season with wood. People have told me I would use 3-5 cords of wood per year. The season barely started and I probably used 1/2 cord already! I guess I will go over the 5 cord estimate. I dont think I have more than 5 cords seasoned.
Thanks for the calculations woodgeek.
