Hello all, I installed my wood stove this weekend. It is a Country Stoves ST210, I installed about 5.5 feet of double wall Selkirk stove pipe inside which included 2 45 degree elbows connected to each other to provide enough offset to avoid a joist in the ceiling. The double wall stove pipe connects to a supervent decorator round ceiling support and then 15 ft of supervent class A chimney. All of this is 6 inc diameter the same as the stove. All was fine, I lit a fire Saturday evening after the installation was done then let it go out before bed since this is my first wood stove I am not sure how to do overnight burns yet. Then Sunday morning I woke up and started a fire from a cold stove at about 7 am with an indoor temperature of 65 ( we have propane furnace also) and an outdoor temp of around 35. All went well I was quickly enjoying that glorious wood heat for the entire day Sunday. Again before bed I just let it all burn out. This morning I attempted to start a fire in the cold stove and smoke began to pour out of the open door so I shut the door and smoke came out the vents on the stove. I was thinking that maybe the chimney was just full of cold air and that I just needed enough heat to overcome the cold chimney so I continued trying to get a fire going which eventually I have a couple small pieces burning but all the smoke was just filling house. After a few minutes of this I gave up and quickly got the burning pieces of wood out of the house and the smoke out by opening all the windows to the 4 degree air, my wife and kids were not pleased.
Anyway I am not sure what to do in this situation and am looking for suggestions to make sure this does not happen again. It was quite cold this morning and there was definitely a temperature inversion going on outside. My house is in the mountains with a good view out over a couple valleys which had low cloud cover in them which I am above. Was this just bad timing because of the temp inversion outside? Should I be doing something to warm the stovepipe/ chimney a bit before lighting a fire?
Any advise is greatly appreciated.
Thanks
Thanks
