You don't need a lot of heat, just a way to move the warm air that the stove will generate to move around the house. I think you may like some of the stoves I suggested.
If you want something to compliment the bar you can get the Ideal Steel with custom made graphics, maybe a pint glass full of Guinness? Just a thought not saying it is the best stove for your setup.
http://www.woodstove.com/geared-2u-design-book
The downstairs has a clay flue and there's nothing combustible behind the brick. Do stoves give off more radiant heat with better clearance? Basically, would it heat just as well if it's pushed all the way back into the hearth, with only a few inches on each side vs having it out further "letting it breathe"?
If done correctly with fusible link dampers you could put registers in the ceiling of the basement that will allow heat up stairs. Or do like I did and put in a fan to blow cold air from upstairs to the basement so it forms a thermal loop with the hot air going up the stairs to replace the cold air.
I installed an Airflow Breeze Ultra, I have it blowing the cold air from upstairs into my living room downstairs where the stove is located. I installed it on the furthest point from the stairs so it would form a thermal loop to the furthest back room upstairs. I have a fusible link register installed upstairs just incase we have a fire, I used Roxul and rigid foam board to make my air tunnel between the ceiling and the upstairs floor. Just keep any protrusions in the ceiling 10+ feet away from the stove for codes. I also installed a CO monitor above the vent upstairs just incase.
This is the fan I Used, I got it because it has a remote and it has an in-line temp sensor that kicks it on and off, but I have found I just keep it on all the time on medium when we are awake and switch it to high when we go to bed at night due to it being noisy on high.
Links:
Register: http://www.hartandcooley.com/produc...inum-1-way-register-ms-damper-1-2-fin-spacing
Airflow 1000: (broken link removed to http://www.smarthome.com/airflow-technology-1000-0011-airflow-breeze-ultra-with-remote.html)
I don't have any pictures, I keep forgetting to write a review on it as it just works in the background, it works OK for me when it is warmer outside (uninsulated house) but with an insulated house I bet it would work 1000 times better.
Here's our Propane usage/bill info:
Nov. 11: 89 gallons
Dec. 13: 111 gallons
Jan. 17: 202 gallons
Feb. 25: 225 gallons
all @ $2.59 a gallon
Just one stove/insert with liner and install will probably be closer to $4000. There is not that much drop-off between a large and a small insert plus you have other cost that remain the same.
Why a medium stove? One cord of wood is 128 cu ft. Let's assume you would fill your stove the same as you stack the wood to dry (usually you would stuff the firebox more tight), that would be a bit more than 4 cu ft per day. Two loads of 2 cu ft per day (one in the morning, one in the evening) would be all you need to fulfill your heating needs (in one of the coldest months we had). Thus, one medium sized stove will be plenty for your home. Your problem will be to figure out how to move the air around your large home.
Maybe take a look if one of the stoves of the BlazeKing 20 series would fit. They will give you a long enough burn time without heating you out of your home unless it is in the single digits outside.
I personally would hold off on the second insert/stove upstairs until you know how well the downstairs stove heats your home but that's your decision.
Does this include heating the basement? Where do you set the thermostat? DHW and dryer?
I would go stove over insert any day, but that's just my opinion.
I'd still be thinking really hard about a Woodstock. A cat stove would be more versatile in your well-insulated situation, and they're all rear vent and would work with your fireplace. The really big plus is that they will take the stove back if you buy the wrong one. You can call and talk to them about it. They are really nice people.
No reason to rush, so I'll just take my time choosing a great stove.
I'm also going to start splitting and stacking lots-o-wood!
I am not an expert by any stretch. If it were me and if most of my time is spent on the level above the basement thats where the stove would go. I believe you said it is wide open with high ceilings. I have a similar set up. A free standing stove in the basement and a new this year insert in the living room on the first floor. The stove in the basement worked its tail off but never gave that warmth we wanted. The insert in the living room gives a warmth that the stove on the lower floor could never match. To me its a no brainer, put your stove where it'll do the most good, and where you spend your time. With an insert I dont think you'll need to worry about cooking yourself out of the room.
Can you zone your heat? Turn it up in the basement and down in the 1st floor and you will see how well the heat travels upstairs. Or use some electric space heaters if your circuits can handle it.
