BK: How to OAK
That's actually a pretty accurate description for our climate. This morning I rode my bike to work at 50F, with 80 expected by the afternoon. Stove is cold, as you can imagine.
We've been seeing forcast temps in the mid-30's to low-40's every night, but the hard frost on the lawn and our windshields many mornings tells me those forecasts must be optimistic. If I'm scraping windows, it must be colder than mid-30's!
But we're still seeing 60's almost every afternoon, so I've only been running half loads of mostly red oak for the overnights, letting the stoves to out by noon each day.
Reactions: Tron
Nope, forecasts are always for 5-6 ft up, and it's colder at the ground (up to 10 degrees!).
No optimistic weathermen. Merely folks not knowing what the weatherman actually forecasts...
No, I understand that perfectly. But my truck's windshild isn't on the ground, it's 6 to 7 feet off the ground.
And the ground should be warmer than the air at end of summer and when average temperature is well above nighttime low. So if night time low is reported as 37, and average for the last 24 hours or week is in the 50's, there's no reason we should be seeing frost on either the ground or the windshield of a truck that's 7 feet off the ground.
Clearly the reported temperature is way off.
Reactions: Tron
I have two very accurate thermometers in the yard, both on trees about 6' up, and they agree mostly with the forecast. Right now the forecast is 45 and my measurements are 47.
The main reason for a difference is not height above ground, but location. The forecast is never for your actual location, and temperatures can vary quite a bit. Depending on whether you're like in a neighborhood with houses all around or out in the open field.
