I can't believe I am reading this. Last time I was in, Blaze Kings were perfect, and burned for three days, no smoke and no creosote. Plus, they heated 3000 square foot Victorians, of the original variety. I am disappointed to read these posts.
Seems crazy to remove the cat element(s) for cleaning. They are right there front and center with the dirty side facing out. Pretty awesome access. Maybe the King is different but I didn't think so. The only thing better would be the cast iron drop out cat frame on the woodstock fireview that lets you easily remove the cat and inspect it on the bench all with no gaskets being disturbed.
I have seen no need to brush the cat. The thing stays very clean all on its own.
)I have read on here a few times about the "batch" of reverse wound springs in the thermostats. The fact is, there were 6 in the past 14 years. We gladly replaced them. Those stoves still performed, just inverse to the decal indications.
Granted, but it's not that hard to check, as I describe in a massive thread on this issue:If something is wrong with the stoves performance, it is very, very unlikely to be related too a reverse wound spring.
I have no bypass gasket??? LOOKED up my manual online and ther3 is not one listed, maybe I should glue one inthere?
The bypass gasket seems smaller in diameter than the door gasket. I bought a bunch of extra door gasket in hopes of using it on the bypass....are they supposed to be different?
I'd like to add to this cause it can be very important.They sure feel different. On my newish BK, the flat bypass gasket is like a thin velvet. It seems to be in a terrible place always having junk smashed into it. On occasion, I vacuum out that cat chamber and try to be sure that there is no junk in the sealing area.
I am 95% certain that they are not the same material at all.
The bypass seal is not nearly as important as the door seal.
Chris,
Last season was the first time I pulled my cat. I just pulled it again doing the cleaning.
Last year to get a gasket I called my dealer(Williamson Hardware in Williamson NY.) to see if they had the gasket.
They had to order it.
They would not drop ship to my house so I had to drive the 45 mins to their location.
I forget what I paid but I also paid shipping..I want to say like 20 bucks.
Anyways I suppose any 2"x30" cat gasket will work but I like using what came with the stove.
But it is crazy for me to obtain the gasket that way.
So what should I do..just order a cat gasket off the net from somebody?
I would like 3 at least because I plan on pulling my cat at least once a season for maintenance.
This stove really works..I'm starting my 4th season with it.
I cut my wood consumption by a 1/3 and we are way warmer!
We had a non cat BK king for around 14 years before this one.
Didn't wear that one out but reading here and because of the Fed rebate at the time we updated and so glad we did.
1.70/ft sounds good to me. Thanks.
![[Hearth.com] Blaze king king tune up... [Hearth.com] Blaze king king tune up...](/talk/proxy.php?image=http%3A%2F%2Fwww.firecatcombustors.com%2Fv%2Fvspfiles%2Ftemplates%2Fhomestead%2Fimages%2Fbuttons%2Fbtn_addtocart_small.gif&hash=d1a38ef7413be1189f6735232855d11d)
![[Hearth.com] Blaze king king tune up... [Hearth.com] Blaze king king tune up...](/talk/proxy.php?image=http%3A%2F%2Fa248.e.akamai.net%2Forigin-cdn.volusion.com%2Fkhvnr.xawsq%2Fv%2Fvspfiles%2Fphotos%2FSKU_ACIG-3-1.jpg%3F1314975086&hash=2a988a6037e5f5c7da9d6fd47d8ed64a)
