I purchased a Blaze King Sirocco 30 in early November and had installed at the same time. One question in regards to the CAT operation in this stove: When should the CAT be glowing? In my stove it is glowing when there is new wood to burn, but the CAT stops glowing a few hours later. Best I can tell even if I have a large pile of hot coals the CAT is dark. Is this normal or what should happen? The thermometer is in the 'active' zone, so I think it is working. The reason I ask this is my burn times are not as high as reported on here. I know there are many variables, but even when warmer temps outside I cannot get 20 hours burn time. In the recent cold snap with overnight temps in the single digits/low teens I got about 8-10 hrs of real heat. Don't know if this is normal or not. I usually keep my temperature setting around 2.
My house is about 2,300 sq. ft. ranch style home. Built in 2010, with good insulation and windows. Chimney straight up through roof, about 23' (Double wall and Class A). Need advice with those that are more familiar with these things as this is my first wood stove. Previously had a pellet stove. Thanks.
![[Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing? [Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing?](https://www.hearth.com/talk/data/attachments/121/121312-18f49e586387328045ad81a3766addbf.jpg?hash=DrBDt02nMm)
![[Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing? [Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing?](https://www.hearth.com/talk/data/attachments/121/121313-1f64ca9bbc29486219e211faa5ba2d1f.jpg?hash=KmpYTYue5f)
![[Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing? [Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing?](https://www.hearth.com/talk/data/attachments/121/121314-f69ac05e6fbc3d77b676b141a768d89c.jpg?hash=en6BYe7Tvl)
![[Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing? [Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing?](https://www.hearth.com/talk/data/attachments/121/121315-cfb2b036936de732009705b20af74790.jpg?hash=in_vVuLiA-)
![[Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing? [Hearth.com] Blaze King Sirocco 30 - Should the CAT be Glowing?](https://www.hearth.com/talk/data/attachments/121/121316-2a6fc3331e94ff2b7b33d5a7677f46e0.jpg?hash=VPHEpYVLOv)
