i bought a brand new full size trash can and have it in the house, i fill it full of wood and spray a little bug spray around the rim before putting the lid on so if there are bugs inside they stay inside. repeat every few days.
EJL923 said:I think Jake convinced me to build a wood box. I might even put wheels on it like a wheeled cooler to roll it over by the door to fill. Actually, that's exactly what im going to do!
I'm too paranoid to vacuum around the stove lest I inadvertently pick up a hot coal. In fact, I won't even sweep it into a dustpan after closing the door until a good amount of time has passed.Wood Duck said:I just vacuum to keep things tidy.
LLigetfa said:I'm too paranoid to vacuum around the stove lest I inadvertently pick up a hot coal. In fact, I won't even sweep it into a dustpan after closing the door until a good amount of time has passed.Wood Duck said:I just vacuum to keep things tidy.
Slow1 said:I have a two rack system that holds several days worth of wood in total. It is a wire "baker's rack" that came as a single unit with wheels - option to build as two (one without wheels, one with) which is how I assembled it. So I have one short two shelf wheeled rack to bring the wood from across the room to the stove and another 3 shelf unit that sits by the stove to store wood. I use from the stationary unit first, then refill from the other or (more often) I pick from the various shelves the pieces I want to feed into the stove as I load. Then I consolidate the remaining pieces off the wheeled unit onto the other before re-fill time. This gives me pretty good stock rotation.
Like others, I rather like having the wood sit in the house and warm up and/or dry off whatever ice/snow/rain may have fallen on it. I have not had any significant bug issues. Occasional spider here and there in the fall, but once we get a good week of freezing temps it seems the bugs die off and go into hibernation.
Overall it hasn't been much extra mess and being able to sweep up whatever falls from under the racks is nice. I do this after each load and use a dustbuster to suck up the pile. I haven't had any issues with hot coals falling out of the stove to land in the pile - perhaps because I haven't had coals build up high enough to be near the base of the door? I just don't recall it happening... now that I said that I bet it happens tonight eh?
woodchip said:snowleopard said:Chiming in from a cold climate. A woodbox wouldn't work for me because I want the air circulating around the wood when I bring it in. I almost always pre-warm my wood because it's not effective to put extremely cold wood in the fire, and the manufacturer warns against this, as it can cause damage to the stove.
A very interesting thought there, wonder how much quicker it would be to get up onto a secondary burn with warmer wood than refilling a firebox with very cold wood........
weatherguy said:Slow1 said:I have a two rack system that holds several days worth of wood in total. It is a wire "baker's rack" that came as a single unit with wheels - option to build as two (one without wheels, one with) which is how I assembled it. So I have one short two shelf wheeled rack to bring the wood from across the room to the stove and another 3 shelf unit that sits by the stove to store wood. I use from the stationary unit first, then refill from the other or (more often) I pick from the various shelves the pieces I want to feed into the stove as I load. Then I consolidate the remaining pieces off the wheeled unit onto the other before re-fill time. This gives me pretty good stock rotation.
Sounds like a good system Slow, can you take a pic?
