Ram 1500 with an axe...
I'm burning mostly norway maple with black locust mixed in. Thanks.Most likely. What wood are you burning?
After what I saw last night, so do I....I still think the stove should be burning at a slower rate, but I could be wrong
Maybe my splits are too small? I did that purposely to get it ready for this year....
I did pack 6 splits together, in a bunch, but didn't see better results, you had an article on block off plates, I do not have one, I have no issues with getting heat into my room, just the fact that I need to reload too often.....TySmall splits will outgas quickly. For the same volume of wood there is a lot more surface area exposed. Try some thick splits tonight. You should see a notable change.
Your right, what?.....If you are reloading to often, some thing is wrong.
Hi Kapt, yes some splits, are near what you said 2*2, some bigger and some, not your typical size splits, mostly Maple, I split it small to get it ready for this season, but I packed 6 pieces together and it still burned at the same rate, I am heating a 550 sq ft area, it is uninsulated and I have a total of 10 windows including the doors, so there is a lot of glass with plaster walls built in 1943.You say "small" splits, what size? 2"x2"x16"? You also mentioned "Flame only", are you talking secondaries?
I burn red oak, around 20% moisture. Recent nights I've put in 3 or 4 splits that are about 4"x4"x18". Primary flame, from the wood, lasts about 2 hours. Secondaries, the gas jet type at the burn tubes usually start about 30 to 45 minutes after the stove is lit and will last from a half hour to an hour. Lazy secondaries, I call them Aurora Borealis secondaries, will float around the fire box for the next few hours. With 3 or 4 splits in at 11PM I still have useable heat and a hot bed of coals at 6am.
It sounds like you might have one of two problems. (Maybe a little of both) Is your primary air control working? When I light my stove there is a full box of flames with the air control fully open. If, before everything has time to heat up, I suddenly close the primary air most of the flames will disappear. This proves the air control is working. On the newer Montpeliers there is an access hatch held closed with two screws just above the air control handle on the top of the stove. It was added to fix/adjust the air control without having to remove the entire outer skin. If you try the above test and do not see a radical difference in flame you might want to check the control linkage.
Have you ever measured the draft? Too much draft is going to suck air in via the vents that are always open. These vents are supposed to let enough air in with normal draft so the fire burns cleanly with the primary closed.
KaptJaq
