Hello everybody!
Been having fun reading many of your threads here on this fine forum, thank you so much for all the great information.
I was wondering if I could get your opinions on a couple of topics that I seem to be confronted with at the present moment.
This is my first year using a wood burning stove, I got the Jotul Oslo, and I have used it maybe 6-8 time so far (hasnt been that cold here). In reading the manual I says that the optimum temperatures are between 300-600 degrees.
Somehow I wound up with two thermometers and they are placed in the corners of the stove as indicated per the manual. The problem is that they are both giving me different temperatures and are about 100 degreees off from each other. Right now I'm using a Rutland and a Chimguard thermometer, the Rutland running higher/hotter.
My question is this, is there a good reliable brand of stove thermometers that are most commonly used by the wood burning community?
My second querie deals with regard to burn time, as I am sure many of you know this model is rated for a 9hr burn time, I know that this is under optimal and controlled conditions. While I of course would like to do long burns at night I have been encountering the following problem, if I load the heck out of it (4-5 decent size log sections) and damp it down a good bit (say 3/4 of the way) it will shoot up to 600 (5oo for the second thermometer) degrees withing about 45 minutes. If I damp it down hard/almost closed, it will burn longer of course but it will only hover in the 300+ degree range (200 on other thermo). Can any of you with this model maybe shed some ligh on this topic, I would ideally like to keep it at close to 400 degrees but can only achieve this if I dont load it up too much but then I have to reload it more often. What temperature do you guys shoot for/is ideal for the overnight burn and how many hours do you guys average.
I almost never run this stove with the damper in the full open position as it will get real hot real quick for obvious reasons, I would have thought that the dampening action would have been more gradual, it almost seems like its either open or just about closed.
I am not using this as my main source of heat but as a supplement but once it gets cold I will probably fire it up every night when I get home from work and of course full time on the weekends.
So far I am really enjoying it and it sure is a lot of fun, I gotta say though, it definitely spoils you, I never kept the old homestead past 70 degrees before I got this contraption, but now that just doesnt seem right.... Too cold...BRRRRR!
Thank you all in advance and I look forward to some of your comments and opinions.
