Can’t Adjust Flame
Jack819
2
Lansing, MI
I recently installed a Kingsman IDV44 with the IPI and the pro flame remote. It requires changing out the manual flame adjustment for a electronic stepper valve so the flame can be adjusted remotely. It starts and runs fine, however the flame cannot be adjusted down. The flame is extremely tall (almost touching the top of the firebox). I have tried resetting everything, reinstalling the stepper valve, testing the stepper valve (it read the correct 25.4 ohms) with no luck. I can hear the valve make noise when I turn it down with the remote but nothing happens. It is almost as if there is just too much gas going through it. Do I need to install some sort of regulator on the gas line?
Have you measured the gas pressure coming THROUGH the valve at the manifold port?
I have not. I need to get a manometer from work. If it is measuring too high, how do I adjust it down? There does not appear to be any adjustments on the manifold.
There should be an adjustment screw on the regulator. Google it. There are videos.
