Let's see some pics...Is there a point where the cat is to hot or glowing to much that you can damage it?
Yes, could be. 1600F is to build in a safety factor. Sometimes temps can go up quickly.
Correct it's the stove not the insert. I just want to make sure it's not to much heat for the cat.I imagine this is on your stove and not your insert since you said you don't have an actual temperature reading. I have seen similar glowing on my insert and the temperature was indicating around 1000F.
Is there any way to replace the gauge with one that includes the actual temperature? Perhaps you can install a thermocouple with digital readout similar to the ci2600 insert.
Sent from my 7040T using Tapatalk
Yes it is easy to do may just do it.Is there any way to replace the gauge with one that includes the actual temperature? Perhaps you can install a thermocouple with digital readout similar to the ci2600 insert.
They don't lag much when the tip is 1/2-3/4" away from the cat surface. Sometimes you can see the probe needle moving. I can control the rate of gassing, and the temp of the cat, with the air control on my stove. Perhaps you don't have that degree of control since your thermostat is making adjustments independently of where you set it.Yes and gauges lag so it would be tough to have to manage control of cat temps.
Bk seems to think 1800 is the limit. Then took all the numbers off of the cat meter dial! Not needed!
Heh-heh. Your curiosity is finally getting the better of you, isn't it?Condar makes many (most?) oem cat probe meters and also sells them with numbers....I might make it my next stove farkle.
When my cat is the hottest on the cat probe meter is not when it is the brightest glow. It's odd that way. Sometimes part of the cat isn't even glowing.
But yes, sometimes one part of the cat may glow when another section doesn't. Depends how that particular load is gassing, how the air is flowing around the wood, etc.As with stove temp, I figure the lower the better as long as I'm burning clean and getting the heat I need.Condar used to say 1700 is the limit. Lots of different numbers floating around.
Different probe setups will read a little differently. On my SIL's Dutchwest, for instance, I saw a higher reading when I replaced her old probe with a new one which had the tip a little closer to the cat surface. As you and you are burning clean when you look at the flue, and are getting the heat you need, I'd say you are doing well. Is there any way to see the cat on your stove? Can you look up through the window, or look in around the bypass rod hole and see the cat glowing?The cat on my stove recommends not going over 1400. I have not seen over 1200 yet. I don't know if I'm not burning it correctly or turn it down to quickly. I routinely seen temps between 700 to 1000. Everything seems to burn great I just dont know how some people see temps at 1500 plus. It's definitely hot.
Right, just take out the old probe and measure the actual probe length, from tip to the first flange. That will be the probe length you want to order. Or if the probe is on top of the stove and extends to over the cat surface, you can remove the probe, then stick carefully stick something in the hole until it touches the surface of the cat. The subtract 1/2-3/4", and that should be the length needed. Now, the Buck probe comes in from the front, parallel to the cat surface, so this method wouldn't work. redyute's pic is of the old style Condar probe, which still comes with some stoves like High Valley and Buck.This the one that came with my high valley, you need to know what length probe you need before purchasing it, guess you can just remove it and measure the probe on the one you already haveView attachment 191865
![[Hearth.com] Catalytic combuster [Hearth.com] Catalytic combuster](https://www.hearth.com/talk/data/attachments/191/191897-d156b574a70429f3fa2749f7f9e71af5.jpg?hash=HC34kkuyo_)
Heh-heh. Your curiosity is finally getting the better you, isn't it?![]()
Strange...brighter glow should be giving you higher probe reading. Not sure what's going on there...blower interference cooling the probe spring?
Yep, that's fine. I just don't like to see it pushing bright orange or yellow. It doesn't sound like that is what you're seeing, though.When the cat is burning hot I can see it glowing red, from reading here I thought that was good.
It was bright orange no fire in the box.Yep, that's fine. I just don't like to see it pushing bright orange or yellow. It doesn't sound like that is what you're seeing, though.
My cat probe bottoms out often no flame just a red hot glow with orange flame on the inside of the honeycombs,works for me.I'm not afraid to run my stove,if it craps out BK will get a call,I personally don't believe you could overfire a BK?could be wrong,but I did overfire two (2) Quadrafires cracked the sides on both,both replaced by Quad a good thing,poor design I guess.Is there a point where the cat is to hot or glowing to much that you can damage it?
