chimney and new insert plan. acceptable?
CI-Borg
29
Fort Smith, Arkansas
Good Day to everyone. I've enjoyed reading through several pages of posts. I started with a couple of questions but after reading I now have about a million;lol but I'll stick to the original couple. I have removed an old (30 years) Country Flame insert from what I supposed was a fireplace. Evidently the "fireplace" was built with an insert in mind so there are no firebricks, damper, etc. Just kind of a big hole in wall built with common brick and with a 9 inch flue opening in the top. There was never a chimney liner and the old insert was just venting into the firebox. Because the opening is so large I want to reduce the size by adding brick around the openings sides and top. This is for aesthetic reasons because my wife doesn't want a huge insert surround. All the brick surround will be tiled before the new insert's installed. Also, since the hole is so large I plan to fill the sides, back and top with plenty of insulation. Especially since it is an external chimney. Is this plan acceptable? Since I only have a 9 inch flue opening should I include a blocking plate as well on the top? Maybe made with durorock since I'll probably be using that with the insulation anyway? Haven't purchased a replacement yet but am leaning toward a Jotul C350. Thanks, this is a wonderful resource. Mike
chimney and new insert plan.  acceptable? the hole in the wallchimney and new insert plan.  acceptable?flue opening on the topchimney and new insert plan.  acceptable?old Country Flame insert
sounds goo i would just say dont pack the fire box full so the insulation is right against the insert leave a little room
Why not put a freestanding stove in there?
That may look much better in this application than an insert and it looks like you will have the height. I assume there are no combustibles behind the brick?
Reactions: claydogg84
thanks for the feedback bholler. grisu, I thought about that and if the "hole in the wall" looked half as good as the one in your picture I would consider it strongly.
I just wanted to say I had that exact country flame stove for over 20 years and it was a great stove. Yours is definitely done for ;)
Besides cleaning you could also just paint the brick. Or add some insulation like mellow did: https://www.hearth.com/talk/threads...lating-my-fireplace.75755/page-2#post-1635483
Going for freestanding stove would give you more options and probably look better in that large fireplace, even when you add some bricks to reduce the opening.
The Jotul C350 would look good in there. Putting up a block off plate would be super easy in this setup if this is an exterior wall chimney. If not, I don't think I'd bother.
I read the thread from mellow and that;s exactly what I planned to do. Instead of painting the durock would there be any advantage to facing it with shiny aluminum? I know shiny aluminum is used in various places like attic roofs to reflect heat. Might not apply for this application but just curious.
Just make the block off plate with a piece of sheet metal from Home Depot (under $10), put roxul insulation above then fashion a block off plate, you can paint it black or any color for that matter.
That looks like metal so you could fasten the block off plate with magnets, I bought a small package at Home Depot and that's what I use to keep my plate on.
How are you going to attach the aluminum to the durock? Seems like that would be more of a pain than it would be worth in gains.
I only painted mine black incase I left my surround off, I put it back on as I feel it does work better with the surround trapping the heat in the insulated firebox.
Since I would be starting from scratch with the insulation/durock I thought maybe of wrapping the durock with heavy foil. The foil would wrap around the edges of the durock and be trapped by the pressure of the insulation, Not real durable sounding I know but once the insert is in place it shouldn't have to be. This is all new to me and I was just kind of thinking out loud.
