When I bought this property, we did a gut renovation on the house but put off re-doing the roof. The chimney was obviously too low, so decided to add a draft inducer by Tjernland to get adequate draft. It has worked great, but leaves some concerns.
One being that anything mechanical will fail over time and needs to be cleaned periodically. Another concern is dealing with any power outages. I have a portable battery sogen that will provide power to the circuit, but again it is something to deal with.
So some ideas:
1. Add an extension pipe to gain adequate height and no longer use the draft inducer.
2. Add the extension pipe and then place the draft inducer on top of that pipe. The downside being that it would be a beast to get that thing installed at the new height.
3. Add the extension pipe and use a collar draft inducer IF adequate draft is not obtained.
Would appreciate any thoughts or insights on these options.
So some ideas:
![[Hearth.com] Chimney Extension [Hearth.com] Chimney Extension](https://www.hearth.com/talk/data/attachments/306/306982-9feba265af532c217c878df82e373a2f.jpg?hash=BNeEvlhuaK)
![[Hearth.com] Chimney Extension [Hearth.com] Chimney Extension](https://www.hearth.com/talk/data/attachments/306/306985-e3d1caec9cda84229178a07185c480a5.jpg?hash=q6tG7rcv8c)
![[Hearth.com] Chimney Extension [Hearth.com] Chimney Extension](https://www.hearth.com/talk/data/attachments/306/306986-7a99870a4107cfa846d6512aecd65a78.jpg?hash=9M8s_XHrwB)
