Hello-
Finally finished the install of a Econoburn 200. The boiler is inside a small concrete block outbuilding that has a wooden structure around it. I am putting in the chimney and have a question- due to the location and structure, I need about a 6.5' horizontal run out of the boiler to my cleanout tee where the vertical section begins. I contacted the chimney manufacturer ((Selkirk) and they expressed doubts that I would get enough draft with the long horizontal run, the exposed chimney, and the cold Wisconsin winters. They suggested I call Econoburn. I did, they couldn't say, other than to make sure I have a barometric damper and to measure the draft. Anyone have a comparable situation and found a long horizontal run an issue? Thanks for your time.
