Not drawing well, smokes house, wife threatens to spend thousands despite the fact that we make under 10 fires a year over the holidays / during the short DC winters.
Approx. 28 X 28X 24(d) fireplace with damper set toward rear, older but decent clay lined chimney with stepped smoke chamber. I believe that it is a Rumford. I have always thought that the damper is set too far back and generally the problem, so the question is, what step(s) to take first in this low use situation?
This Old House video seems really comprehensive and not that expensive if I am willing to take the time and do the work. It appears to create one sealed smoke pathway from the top of the firebox to the great outdoors, but I would need to remove the existing damper and webfish says "It is my opinion that a decent damper at the fireplace level is best". Once I cut it out, its gone for good.
- Should I, Take out (cut the frame) the damper and install a rooftop damper first and see how that works?
- Same as above but install a liner and create a masonry roof to the firebox going around the smoke shelf?
- Same as above but remove the smoke shelf. I am not sure how necessary that is. I assume that a straight liner would be better than curved to go around the shelf.
- Other?
![[Hearth.com] chimney upgrade to1920's (Sears like) bungalow in DC [Hearth.com] chimney upgrade to1920's (Sears like) bungalow in DC](https://www.hearth.com/talk/data/attachments/304/304897-2d8b8b84712ed06136b1a8692ea57a9c.jpg?hash=_flankHpki)
![[Hearth.com] chimney upgrade to1920's (Sears like) bungalow in DC [Hearth.com] chimney upgrade to1920's (Sears like) bungalow in DC](https://www.hearth.com/talk/data/attachments/304/304898-d439f9df09269272d59bc3c841740457.jpg?hash=s5jx2aSzrX)
