Cleaning the smoke chamber before liner install
Benchwrench
259
State of Confusion
A sweep come out last week to clean my chimney before my insert gets installed however and as I look up into the smoke chamber I still see shiny creosote adhered to this area.
Can someone recommend a viable way to strip this blackness off the bricks that line the smoke shelf? The brick work is stepped or tapered towards the flue and this clinging tar is attached to the underside of the exposed area like steps or "shelves" that makes up the design.
I'd be willing to buy whatever needed within reason as this is a "one time" use since the next step is to reline the whole thing with a 6" liner and this area is going to be packed with Roxul.
I am curious if just a small stiff broom or whatever might work. Any ideas of a tool you guys might recommend?
Thanks again guys, looking forward to staying warm and posting pictures of the job,
Bench
Wear a mask and goggles.
If you can't get all of it off mechanically, there are chemicals for glazed(stage 3) creosote.
(broken link removed to http://www.northlineexpress.com/item/5SS-ACS-POWDER/ACS-Powder-Creosote-Remover)
thanks, for the heads up on safety.
I'll check around the hardware stores for a small steel broom or something that might fit the bill.
As it stands the FP is not going to be used until the insert gets installed as I am permanently modifying the damper to accept flex.
I just want the job to be better than it is, I know there is much more creosote that can be removed.
I do appreciate all your guys help as I glean much from this forum,
it's very valuable information for both new installs as well as maintenance.
Bench
For over twenty years I pulled my old insert and cleaned the biggest part out of the smoke chamber with a garden hoe and then used a long handled steel bristle brush on the rest.
[Hearth.com] Cleaning the smoke chamber before liner install
I thought that once the chimney was lined, there would be no more need to remove the insert for maintenance.
A garden hoe, for what purpose? is it to remove the debris on the smoke shelf (broken image removed)
I might have to check around the web for steel brushes as I don't think ACE or Lowe's is going to have what I am looking for on their shelf.
If there is no liner attached as is the case with many older inserts being installed as slammers directly into an old fireplace, you may need the hoe.
pen
That is right. I haven't had to move that sucker back out of the fireplace since the liner install in 2006. The scrapping was before. Like you are doing. Do it. Line it. Fuggidaboutit.
