While gazing into the innards of my VC Encore 2n1 stove, I saw an opportunity to apply a little high-tech in order to better control air feed within the stove:  take direct control of both primary and secondary air feeds by using a microcontroller with servo actuators on the air doors and thermocouples for temperature feedback.  Game changer!
The primary goal here would be to have the ability to control both the stove body temp as well as the CAT combustion temp. The dc-servo actuators on the air doors would be able to positively regulate airflow through each air plenum - MUCH better than the existing thermo-spring in the VC stove. They could even totally shut down the stove if wanted. Burn performance data could be written to and SD card for post analysis. I will employ a 4x20 LCD display for user interface with button access to operational modes, user settings, etc.
Should be a fun project.... I have most of the parts to get started here in the shop now. I'm just getting the programming menus and LCD layout set up... more to follow...
   this should be a piece of cake and fun at the same time for you.
