Most modern stoves will want at least 15-16' of flue, but there are a few exceptions. We've had reports of some cat stoves working ok with a shorter chimney. In non-cat the Quadrafire Isle Royale and Pacific Energy stoves do ok with a little less. I have a friend that has a Summit running on about 13 ft of flue that is working ok.Honestly we don't have a set in stone budget. Depends on what we get out of the dw. So it needs to 15' above the stove?
I can think of a couple Fireviews (cat) that run OK on 13', including the one I sold my BIL. Manual says 14.I have a friend that has a Summit running on about 13 ft of flue that is working ok.
That's the shortest I recall seeing. As mentioned, you can always add another section of chimney, you just need to brace it if it's over 5'.Yep, you're gonna need to go big, trying to heat from one end of the house. Unless you put the Cumberland at the other end of the house....but feeding two stoves is a pain, and you've got 8" stack on the Dw.That is gonna be a tall order from a 2.4 cuft stove.
I load the Dw from the side, and no lip is no problem. I'm seeing some pics of the Cumberland with ash lips, front and side. Options you can get, maybe.qf cumberland is there is no lip on the side where you load firewood? Anyone had an issue with that? Our dw has a 2" lip that helps keep coals from rolling out.
Yep, The Gap isn't that much bigger. With their cat problems (wet wood?) they weren't getting much heat from the Dw, either. With dry wood, and the blower on the Dw, it will put out some heat but not enough to heat that space, from that location.I would think that the Cumberland Gap will at least meet or exceed the performance of the current 2460. That said I recommend going up a size to the Isle Royale.
Another big cat, but I think it's less costly. Closest dealer is about an hour away.take a look a the Kuma Sequoia
Did you re-split the splits and test on the freshly-exposed face?Most of the wood was 20%
Great, hope it works out well for them.The dw is spoken for
