Hi…it has been a while since I have posted on here. But as always this is the best place for answers on problems with wood boiler systems. I thank every one for that here.
I have a Shaver Wood Boiler as a heat source for a radiant heating system. I cut all my wood a year ahead so it is dry. I do not have a secondary storage tank because I do not need it, living in Tennessee.
However, a couple of years ago I chose to just forgo stove pipe to extend the chimney on the shaver. It always clogged so badly I tried getting rid of it and as far as creosote have not had a problem at all with the stack coming out of the unit.
But I would like to revisit this in order to vent the smoke away from the housing structures more. I believe I understand what causes creosote and I really don't want to use more wood to keep throwing heat up the chimney when I don't really need the heat for our system. I have finally conquered the boil-off issues with this boiler after several years and I don't want to increase that problem as well. And yes I know the Shaver is not a premium boiler but it works for what I need. Also, I make sure that the seal on the door is god every year and caulk it again if needed.
My question is, with double walled SS pipe make a lot of difference for this issue? It is expensive only to find I am going to pull it off because of creosote build up again.
Thanks in advance, RH
