Cutting Down Splits... Any Ideas?
I also sometimes use a miter saw with a framing blade. I’m not sure I would want to do a whole winters worth of wood at once, but maybe a weeks worth at a time.
Reactions: Jeffm1
All of those are great idea's, also you use a band saw
Miter saw will work. Be careful. Irregular shaped splits will occasionally bind the blade and then it gets spooky! Buddy of mine "helped" chunk up a pile for me. Unfortunately his eye was trained for very long pieces for his add on furnace:eek: I spent quite some time making bigger into smaller etc. Rather not do it again!
Reactions: Stinkpickle
Some where in the archives of Hearth.com is a great thread from like 8 years ago which answers this question with the most effective method of cutting down large quantities of firewood. If you build a simple jig, you can cut many splits down to size very quickly. Perhaps one of our fabulous moderators will help us and add a link to the old thread.
Take your pick:
https://www.hearth.com/talk/threads/logs-to-long.163667/
https://www.hearth.com/talk/threads/h-frame-for-cutting.67726/
https://www.hearth.com/talk/threads/does-a-cut-off-saw-or-chop-saw-exist-for-wood.67273/
Reactions: dafattkidd
TreePointer, Bingo! Thanks! It was a post from Zap from a long time ago that I was referring to. However, in one of the links above, TreePointer posted this picture of an H Frame Saw buck, and that is exactly what I was talking about. The one Zap built had a back to it which served as a guide for the new desired length, but this version will work just as well.
Reactions: Jeffm1
This works for me....got this idea from the forum here...mine is much larger than the one I saw here...I load it up and cinch it down with a ratchet strap and grab my 660 and let it rip...I didn't want to play around with a arm full
at a time.
I tried the miter saw....that was painfully slow and not to mention dangerous..especially if a piece was out of round or had a odd shape to it and not lay flat a perfect you....had more than one piece try to leave out on its own...and slam the blade to a screaming halt. The miter saw will work if you have a small amount but I have a couple cord yet to do....
