oilstinks said:might be 10ft total
BeGreen said:At 10 ft you're under the stove minimum requirements. Forget about the damper, add 4 ft. and a roof brace instead.
oilstinks said:Just how necessary is a damper in the pipe? I have a 13nc if that helps.
stanb999 said:oilstinks said:Just how necessary is a damper in the pipe? I have a 13nc if that helps.
I think if you read the manual it will tell you exactly what is recomended.....
No damper period. The reason is it is precision sized to draft and create the max heat output with the cleanest burn. If you put a damper you are throwing that technology out the window and fuel up your chimney.
Highbeam said:stanb999 said:oilstinks said:Just how necessary is a damper in the pipe? I have a 13nc if that helps.
This logic if flawed. The trouble is that not all chimneys are alike and they don't draft the same. The stove was precision sized to work with the worst case chimney and if your chimney drafts stronger than that minimum chimney then you are defeating all of that precision tuning. Adding a flue damper allows you to adjust your chimney to act like the crappy minimum chimney in an effort to operate the stove as it was designed.
