Woodcutter Tom
I used two welders. Stick welded with 7018AC the lower indented area. I ran a full rod lengths across the section. I was not concerned about warping for two reasons: 1. it already was indented from the manufacturing process and that is what I was trying to fix and 2. there is a lot of structure supporting that section.Nice work! Hope it works out this winter. How long a bead did you weld at a time? My concern would be warping the front?
For the bead I used a 90 amp welder with .030 " flux core wire. There was not excessive heat from this set up. I ran each side as best I could. I am a self taught novice. I was not stacking dimes. There was a lot of grinding and redoing. I needed to fill in gaps and had to change the corners to properly follow gasket path. It was a lot longer process than I expected.
![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/316/316347-c0ef0cac91ced7cfdcba678786f54c0b.jpg?hash=YdtM9NnJDz)
![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/317/317959-ba31ebeb75a0aba2175d0fe62f670e53.jpg?hash=YWENiff2V4)
![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/317/317960-f124ba62cc9c36f31956c86eb8551f4b.jpg?hash=EvwbKG-Xxx)
Double wall inside to 2 36" class A sections above the ceiling.![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/318/318376-a66dca4ab34526b7c684724e84a7129e.jpg?hash=ptPcRkcrKE)
![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/318/318377-68cc8f08d19dd5cd55d8e7d42aabfa41.jpg?hash=CKxWHxop-3)
![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/320/320323-904d9f773a2e6a52957aa4f1cc171078.jpg?hash=FCtNFyWzaQ)
![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/320/320324-1e40556e0169d51ffd982ceb5a9c50b5.jpg?hash=_3kMG_uW5S)
![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/320/320325-ec3a8aaff5057db10acf9272c9a702fc.jpg?hash=PT_vUQPvXf)
![[Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts) [Hearth.com] Dialing in the Drolet Escape (1500, 1800 and inserts)](https://www.hearth.com/talk/data/attachments/320/320326-8f80350a2b2733d637ce57e891f0483e.jpg?hash=EHf2i15upB)
