For my reload this morning, which was about 10 hours from the previous load, the stove top temp was just below 250 and probe temp at 500. Upon reload, I opened the air up for a good amount of flame. Five minutes later the stove top temp is a fraction higher, but still below 250. Probe temp at 600. I went ahead and engaged the cat (I have been waiting about 10 minutes even with an adequate probe reading, but thought I'd see what happens when engaging sooner...), and now five minutes later the stove top temp is still below 250 and the probe temp is just above 700. Cat is glowing a little, but not a real strong glow.
Five more minutes stove top is just below 300 and probe is just below 900. Cat still just glowing a little. Had the cat not been engaged, I bet stove top would barely be 250 right now.
Five more minutes and the stove top temp is about 325 and probe just above 900. Cat glowing strong in one spot, but not a solid glow across the whole thing.
Five more minutes the stove top is just above 350 and probe at 900 (dropped a fraction), and the cat glow hasn't changed much.
Five more and the stop top is 375 and the probe is a fraction above 1000. Cat is glowing strong on the ends, but not in the middle.
Five more minutes (30 minutes since cat was engaged) and stove top at 400 and probe 1100. Cat not glowing as much...just glowing on one end.
Worth noting is that my stove top thermometer is placed as close to directly above the cat as I can get it. If it were moved just a few inches, the stove top temp readings would be much less.
During the current instance, I had a little more flame than I usually allow. It was a slow flame, but just a touch more than I prefer. I left the air setting alone (at 1), however, to keep things constant throughout the readings. I have found that if I reduce the air and consequently the flame, the cat will usually glow more strongly. What does this glow really indicate? Anyone know? In the past, I would use the cat glow as a gauge, although this probably isn’t very reliable. In the current instance, if I had NOT had the probe thermometer, I would NOT have left the cat engaged because it did not have a strong glow initially. Consequently, I would have burned up a lot more wood in the meantime. However, with the probe thermometer, I could see that the internal temps were steadily rising, which I understand indicates the cat is working.
A concern of mine with the probe is that the initial probe reading could read hot enough (500) for the cat to be engaged, but that a lot of moisture could remain that could damage the cat. In the current instance I engaged after only 5 minutes, so could there still be too much moisture in the stove even though the probe reading was 600 when the cat was engaged? I usually wait longer to engage the cat, but thought I’d see what would happen in this case....and it turned out the cat temps steadily increased so maybe it is fine?
