Direct Vent Through Basement Wall
danrclem
Burning Hunk
137
KY.
If I exit my direct vent pipe through my basement wall I'm not going to have anywhere close to the 57" clearance to the ground. Can this pipe be turned up to get enough clearance?
[Hearth.com] Direct Vent Through Basement Wall
I’d keep reading the manual, this seems to be indicating min height to wall penetration from the basement floor, probably so you have enough room to connect the wall penetration.
There’s probably some additional guidance for minimum distance above grade, and min clearance for the triple wall pipe.
Reactions: danrclem
Yeh I think that's to the floor. Your distance from grade is probably something like 24" unless it is a walk way.
Reactions: danrclem
I hope you guys are right because the snorkels I've found are very expensive. I'll go back to the manual and see if I can find some more information. I might be better off going to the site of the pipe manufacturer and see what they say.
Thanks for putting me on the right track. I went to the Selkirk site, and it said that it should be at least 12" above grade.
A = above grade, veranda, porch, deck, or balcony US Installations 12 inches (30 cm)
Reactions: Turbo89
That’s more in line with what I was expecting/have seen. Nice work, happy burning!
Reactions: danrclem
12" above grade is usually the minimum, but remember to take snow into effect if need be, where you live. Snorkels can give you more clearance above grade, will usually make the flame better and more movement, but the tradeoff are the Snorkels (14" and 36") are very expensive. Good luck.
Reactions: danrclem
