My H68 has performed very well over the three years I have owned it. It's my only source of heat and I have issues which have just surfaced. I run the stove in manual mode, room temperature. I burn a mixture of corn and pellets. I have been experimenting with the corn to pellet ratio. I had recently brought that ratio down to approximately 25% pellet to 75% corn. I was not happy with this ratio but I have a limited supply of pellet available to I was trying to conserve my stock. I have since returned to a 50/50 ratio. My symptoms. I happened by the stove and noticed the pot was overflowed with corn/pellet and had almost completely stopped burning. I had to clear the pot and restart the stove. I had just cleaned the stove several days before per the Harman book, except the the "fines" in the back of the stove and did not remove the blower cover behind the ash bin. All vent pipe was cleaned as well. It's a short stack vented directly out a window box. Upon restart everything appeared to be back to normal. I have a thermometer on the opposite side of the room and the room temperature will usually keep within one degree of the stove setting. I have always been able to ask for additional heat upon demand, but trying to conserve fuel, I kept temperature in the room around 63 degrees. Last night, again, I woke up and the stove was out, overflowed with corn and pellet. It may have been remnant of lean pellet stock but I don't think so. This time I removed the blower cover and the "fines" cover in the back of the stove. There was some soot in the blower but there exhaust pipe was mostly clear and I was careful with the vacuum not interfere with the sensor. The fines box had significant buildup and that was cleared. Restarted the stove, and again all seemed fine except, I thought, the distribution fan was not turning down after the room came to temperature. I adjusted the the temperature down somewhat the fan began to behave normally automatically to turning up and down to regulate distribution. It has been 18 hrs since I have cleaned and restarted the stove and all has been normal. By normal I mean, in manual mode, room temperature set to 63 and feed rate at #3, the stove has been cycling normally, the 50/50 fuel mixture has been reducing to mostly ash. The burn pile is mostly set back 3 inches from the lip with ash filling the rest. The flame is set back deep in the throat and no fuel buildup. This evening, I decided to warm the room up to 70 degrees. I turned the temperature to 70 and I initially didn't seem to get a response from the stove. Normally I would get a direct increase in feed rate. I gave the stove some time to respond but it seemed content to linger in it's current setting. It would build up a nice hot flame and then turn down to maintenance level with the distribution fan remaining in high mode. Since then I have been able to coax an additional three degrees of room temperature. My temperature sensor behind the stove has not varied in placement since the stove was installed. Quite frankly I'm amazed how synced the stove dial and thermometer across the room has been. I then decided to run in stove temperature mode. Curiously, the fan distribution fan would not come on, no matter the temperature setting. So I reverted back to room temperature so I would have distribution. Mind you, I didn't fool around too much in stove temp setting, so perhaps I didn't let it settle in. I'm worried about loosing heat so I'm being gentle and not forcing the issue.
Any thoughts would be appreciated and I will be sure to respond quickly to any thoughts or suggestions. I apologize if I have not been clear in my description of symptoms or operation of the stove. I am really not clear as to what to expect vis a vis the expected response from the stove and it's actual designed behavior.
They are great if you use them like they are supposed to be used. (50 / 50 corn / pellet max). Read your manual and read a lot here. I can see why it took awhile (3 yrs.) to search out for help because the stove you have pretty much so handles it's own affairs but this forum is a must have for various reasons. Ask questions to save yourself some frustration and costly mistakes.
