I bought my US Stove 6041i pellet stove about a year ago. About 2 months into running the stove, it started putting out a "screaming" noise, which turned out to be bad bearings in the distribution blower. No problem. I called US Stove Co and they sent me a new blower under warranty, no questions asked.
Install the new blower very easily. Ran it for about two months with no issues what-so-ever and it started making the same bearing noise. I called US Stove CO and surprisingly, they sent me ANOTHER distribution blower under warranty.
I have run this blower on and off since November of this year and a month or two of last season and.. you guessed it, it is making the same squeeling noise again.
I took one of the previous blowers and had the bearings replaced (they are sealed bearings); I'm hoping they replaced with a higher quality bearing and maybe my issue will be fixed. I am replacing it tomorrow and obviously wont know if it solved the issues for a couple months at least.
The distribution blower model that came with the stove and that I currently have is: 80472A.
I guess my question is, do I have bad luck? Am I doing something wrong? Is it common to have so many bearings go bad??! its infuriating.
NOTE: I run my pellet stove with a thermostat. It is a high/low working thermostat. The stove is always kept at high, but only puts out high heat when it is calling for heat, but that means the distribution blower is always running at full speed. Maybe the issue?
Help!
-- Brad
Help!
-- Brad
