Ok,
So as per my other post there is now a wood stove sitting in front of the original fireplace. We removed the wood fireplace, replaced with a marble, and placed a Jotul F500/Oslo.
The guys wanted a photo of the room set up:
The door to the left leads out to the kitchen, right behind where the ladder is you can see one of two sets of stairs in the house.
In the other photo you see the larger doorway, and to the left of that is another set of stairs.
The problem is, the heat is building up mainly in this room, the kitchen feels much cooler. The stove room got up to 85F.
Ideas For Spreading Heat From This Room:
1.
Use the central air, put the central air on Fan ON, to circulate.
2.
Place a vent above each doorway at the ceiling to allow the hot air to pass to each room. Possibly a vent with a fan to aid hot air removal from the room.
3
Since the stairs are behind the wall, place a vent there to allow the hot air up the stairs, or place a vent directly in the ceiling to the 2nd floor.
4.
Place a Jotul accessory fan or fans in the room to circulate the air.
Or....place a ceiling fan above the stove in reverse to blow the hot air downward and hopefully out the doors......
Any advice on this layout????
![[Hearth.com] Distribution of Heat [Hearth.com] Distribution of Heat](https://www.hearth.com/talk/data/attachments/141/141475-a6d93bbf81cf1afb1576ccf66c48f417.jpg?hash=nkPeHRVoSi)
1.
2.
3
4.
