The magic heat a.k.a. creosote formation accelerator.
GOOD GOD That magic heat is big!
I built a makeshift kiln today. I put a $15 heater fan in the middle of some stacks along with my dehumidifier.I have municipal electricity which is cheap. My wood went in at 18-20% .
On the one I made, it was not intended to get hot inside, just to evenly move dry outside summer air through. Basically just a wind tunnel. It was large enough to justify two box fans for distribution, but yes, if the design allows nice even flow, then it doesn't take much flow rate to carry away the moisture from wood which dries really slowly.Even a slow setting on a box fan would seem excessive. Would clear the heat much too quickly. Doesn't much take air movement to clear humidity. in a small space. Look at Humidex's and how slow their fan speeds are for thousands of square feet.
I can see the point of this beig a waste of electricity, but this is an experiment
therefore it's ok. I will be rotating in some green wood soon and have further
data. I shut everything down at 2:15 and it was 75f again at 6:15 I collected 80 oz
of water. It is 39f now.
