Not bad considering it includes the cost of installing the linerJust wondering what you folks think of the cost of this chimney liner and fireplace insert installation. The insert is a Quadrafire 3100i which he gave me a discount on due to it being a display model. Below is an itemized snippet of the bill.
Cheers!
If they plan on doing any extra work like that I suspect it would be mentioned in the bid.If it is a good quality install with block off plate and insulated firebox the labor isn't out of line. If they are just dropping the liner it is high.
I don't mention it in a bid because I don't see it as extra work. That is just how I fell inserts need to be installed to work best so that is the only way I do it. When I used to spell out all the work to be done people would always ask to eliminate the plate or insulation. Or no insulation on the liner.If they plan on doing any extra work like that I suspect it would be mentioned in the bid.
That makes sense.I don't mention it in a bid because I don't see it as extra work. That is just how I fell inserts need to be installed to work best so that is the only way I do it. When I used to spell out all the work to be done people would always ask to eliminate the plate or insulation. Or no insulation on the liner.
Just because you get paid to do something doesn’t mean you care or know much about it. That’s the difference between a job and a career.I paid for mine to be installed by guys who do stove installs for a living.
They had never heard of a blockoff plate, felt that an insulated liner was unneccessary, and felt that 12' of uninsulated flue was perfectly adequate for a stove that specified minimum 15' right in the manual.
"Pro" means you get paid to do something, not that you have bothered to learn anything about the thing you're getting paid for.
Obviously there's plenty of pros who do know what they're talking about, but that's not true of everyone who takes money for services.
Between those two and the mods theres really no need for the rest of usThe two of you bring so much good knowledge and experience to this forum, I cannot stress it enough!
Thank you two!
