![[Hearth.com] Draft sufficiency block-off plate vs full chimney liner [Hearth.com] Draft sufficiency block-off plate vs full chimney liner](https://www.hearth.com/talk/data/attachments/236/236165-20fd77e311c082a46508628bfaed3237.jpg?hash=c3zddHaB77)
![[Hearth.com] Draft sufficiency block-off plate vs full chimney liner [Hearth.com] Draft sufficiency block-off plate vs full chimney liner](https://www.hearth.com/talk/data/attachments/236/236166-642205557e1d6e688b1a78abe4145bc5.jpg?hash=1Wtf5pbtKv)
Are those instructions for your stove specifically? Regardless I would never install a stove that way. The flue gasses will leave the pipe and expand rapidly causing the to cool and fo creosote. Which will then require pulling the stove and blockoff plate to cleanNot a slammer install I don't think. Here's a pic the install I'm referring to as an alternative to full liner.View attachment 236136
That is an adsolutly horrible way to install a stove. Is this a ul listed stove? Because if so I am surprised that made it through the approval process.Yes thats from the manual.
![[Hearth.com] Draft sufficiency block-off plate vs full chimney liner [Hearth.com] Draft sufficiency block-off plate vs full chimney liner](https://www.hearth.com/talk/data/attachments/236/236169-69798b587ec22e92765965ec2a72855c.jpg?hash=ZsfO1h7soI)
A real direct connect is bad enough but that is just horrible.It's in most of the Lopi insert manuals. The Hybrid ones w/ a cat require a full liner.
(broken link removed to https://www.lopistoves.com/TravisDocs/100-01259.pdf)
And wisely not allowed in Canada.A real direct connect is bad enough but that is just horrible.
