And what sort of wood heat system would you put in?
they have a ceiling mounted cassette version (which is really only good for new construction) as well as a "picture frame"
This field continues to grow and get refined. Daikin and Mitsubishi now have complementary vertical air handlers that mate with conventional ducted systems. The ducted units do not necessarily have poor efficiencies. The efficiency is still very good and in some cases just a bit less than the true mini-splits but still quite respectable. The main losses come from the ductwork. A ducted system is inherently less efficient due to these losses. The amount of loss will depend on duct sealing, run length, ambient temp and insulation.With extreme hits to efficiency and still quite ugly. Of course, in my opinion. I have a BK which many find ugly too! The ceiling cassette looks like an RV air conditioner. and the picture frame unit like a medicine cabinet.
The ducted minisplits also have poor efficiencies and then you have to realize you've just bought a miniature version of the traditional split system. These days the difference in efficiency and cold weather operation between MSHP and traditional split is not that great. About time too! No excuse for such poor performance as the old heat pumps made. Just like there is no excuse for water heating heat pumps to not be at every home, I am watching Tom's product closely.
Mitsubishi and Daikin now make conventional split systems too, thus the vertical air handler, but with their superior compressor technology. So far they are able to produce meaningful heat at much lower temps than current American technology.Gosh, fine, the ducted units have poorer efficiencies than the wall units is of course what I meant. The efficiency of most all heat pumps is still better than resistance electric. When ducted minisplits are compared to the wall mounted type there are significant efficiency penalties that make the whole system questionable. Might as well just use a modern split system with a central handler and spend extra time on proper ductwork. These days we have to have pressure tests and higher insulation standards than in the past on ductwork installs plus if you can install ductwork inside the heated space then leaks aren't so bad.
Well it's your dream, location and budget to match. Here in southern ontario Canada, im curious as to what near super insulated walls are? All the talk of mini splits and heat pumps is unheard of here for residential. 95% of homes are forced air. Common to heat the slab if it fits budget nowadays. 99% of homes have a full basement. Our minimum code homes are getting fairly efficient and code continues to raise the bar. Next code change is 2018.One needs more parameters: budget, size, climate, personal preferences.
I can outline what I DID do. I built a story and a half over a full basement - about 2500 sq. ft. plus the garage and basement. Used near-super insulated techniques even here in our mild southwest Missouri climate. While I do not absolutely rely on a wood stove, it is my primary source of heat. To accommodate it I mixed elements of conventional and open floor plans - wide, short halls, high and wide doorways everywhere, stove in a central location, return paths for air to circulate.
If money had been no object I'd have built around a masonry stove.
Were I to go to a colder climate I'd have even more insulation plus exterior insulated shutters for the doors and airlock entries at all door. If I had enough wood available I would consider a ducted wood furnace. Maybe.
Lack of insulation, glazing and vaulted ceilings are the biggest enemies to comfort when using space heaters like a wood stove.
