"Drying/holding " box for chunks, odd pieces, etc.
PA. Woodsman
2,257
Emmaus, Pennsylvania
I'm pretty sure that this was talked about before, but how many of you guys have made a holding "pen", "crib", box or such to hold the chunks, odd pieces, smaller pieces that you would usually just put on the top of your stacks? That's what I usually do, put them on top of the stacks of 18" splits, but I started to think about building a "crib" for them and putting it in the garage where it gets like a kiln in the Summer and will have no problem drying even if it's in a crib. If you can post pictures too that would be a great help and maybe give me some ideas-thanks!
5 pallets. Make a square box. Good air circ, cheap and easy.
I'm planning to do this next year when I free up some of my pallets by moving some wood into the shed. But I want to make it only three sided with a removable front for better access. Not sure how just yet. Maybe a couple of old hinges so the front pallet can swing open. I'll have to give it some thought.
Reactions: PA. Woodsman
I'm tempted to build such a thing... I have been just piling the chunks on top of a pallet and leaving they there until burned (I have one for each year). This is for the ones that don't go on top of the stacks easily for whatever reason. So far this has been working reasonably well, but as the number goes up I think I may need to fence them in a bit :)
Great Idea Jags, you could always use 4 pallets, leave one side open for easy access if you don't have enough-to fill her up....
I left the front open on one of mine and used some chicken wire halfway up.
This what I put mine in . Since that picture I made one more and they are 4x4 x 5 foot tall with a metal roof.
  • [Hearth.com] "Drying/holding " box for chunks, odd pieces, etc.
That's what I do. Between campfires and the firepit and shoulder season I try to burn all of mine in a year. Cut them up small with the saw and they dry pretty quick.
I have a pit. I stack some of my small rounds and longer drying wood in a side of my corn crib and fill the uglies in the "pit" in the middle. I don't know if this is correct, but it gets lots of wind and is always bone dry.
Since ALL of my wood comes in on a U made of 3 pallets. The 'oddballs' and uglies go on top of each pallet. It works out pretty good. I'm cutting 24" wood. Seems I don't have more than can fit on the top of each pallet load. it's about 3.3 pallets per cord. works good.
JP
