Hi Everyone,
I'm a new member; hope you all had a good Christmas and you can find some time to go over my post.
Background:
We live in Cortland county upstate NY. Winters here can get severe.
The pellet stove/s will be our primary heat source.
House has 2 levels.
Main floor 900 sq. ft. open plan, 9' ceilings, renovated, foam insulation, double glazed windows, electric baseboard heating, ceiling fans. 2 bedrooms and bathroom off the main open area. Access to the basement via stairs from open area, door at basement level
Walk-out basement 900 sq. ft., open plan, to be renovated with foam insulation, double glazing, electric baseboards. There will be a spare bedroom, shower room and laundry room.
We spend most of our time on the main floor.
We intend to use the basement as a work area (computers), gym and general crafts area.
My wife has weak wrists, so loading chunks of wood is a problem. We prefer to use pellet.
Solutions:
1. To use 2 stoves, one on the main floor and one in the basement.
This will involve maintaining 2 stoves and filling with pellet - lot of work. Plus 2 sets of exhaust piping. We have had a quote using 2 Regency stoves including venting and installation of $12k
2. 1 stove in the basement. Heat rises, cut ducts in main floor and use fans to pull the heat up.
Basement may become too hot for me to work from home in there. Main floor may not get hot enough.
3. 1 stove (ie. Harman XXV) on the main floor - which is where we spend the bulk of our time.
Use the electric baseboard heating in the basement, which could be expensive.
4. 1 stove on the main floor, which will use internal blowers and ducts to push hot air into the basement.
This is my preferred solution. One heat source... see below
Questions:
Has anyone used a pellet stove with internal blowers to push hot air via ducts into another area of their home?
From my research there are 4 brands - Piazetta, Wittus, Ekotech and Rika. Does anyone have any experience of these brands? Are there other manufacturers?
The stoves are not cheap, but are comparable in cost to using a 2 stove + venting solution. The warranties are not as extensive as say Regency and spare parts could be expensive. Any thoughts?
Why do manufacturers use Majolica cladding?
I am leaning towards the Piazetta P963M, which uses 2 internal blowers, can support ducting of 40', 66lb hopper, can provide enough heat for 1800 sq. ft. Cost of $6k - only for the stove though. We have a local (25 miles away) reliable dealer who can install as well.
I would really appreciate any feedback.
We don't have a time restraint and we'll wait until we can find the best way to heat our home.
Thanks and Happy New Year,
Mark
Background:
House has 2 levels.
Solutions:
Questions:
Mark
