My first post - I just purchased a Dutchwest 2461 from a couple and got them down to $100. (Great deal I know ... No pics yet) I am told they bought it new around mid 90's - has the Vermont Castings address on the back plate and a date code of "2727". Anyone know how to decipher the date?
I took the top off and the the cat was clogged up and the steel ring bowed out - need to just buy a new one. THe refractor is fragile but ok. Gaskets need replacing - door glass, front and side doors, ash pan door and damper.
I pulled the back and side plates out to clean any excess ash from behind there - surprisingly not much there.
Cleaned up the outside finish ... knocked some light surface rust off here and there with some steel wool and am getting ready to pull the glass out and paint her up.
Questions:
- Paint or Polish - are there any pros and cons here? I am leaning towards painting as it will be quick and easy - will do a good job with several light coats.
- What brand Paint to use? - does anyone know what paint will provide the most original finish? Stovebright? Big believer in keeping it original
- Brass fittings converted to nickle - although I love original, I am not a big fan of brass on black. Pricing all the fittings is getting up to approx $150 in new parts - would it be cheaper to take them to some one have have the refinished?
- Cat - pricing varies all over the web. from $150 to $280. Are the all the same or is there a stronger value prop for some over others? Is a cat just a cat? Anyone familiar with Condar Cats: http://www.woodstovecombustors.com/dutchwest_new.html
- Complete tear down? It apears that all the joints and cement are still holding up well but have not had any use to see how it is drawing. If it is 15 years old should I just break it down and re-cement all the parts together? There are no cracks or warps so I have no reason to believe anything needs to be replaced.... I just don't know how the joint seals are holding up and if I can avoid it would rather do it next spring!
Am really looking forward to seeing how well this heater will perform when completed. I just bought a Mtn Cabin in the Blue Ridge Mountains - Ranch style with 1,300 sq ft on main floor and 1,300 sq ft on basement level. The plan is to install it in the basement and heat the house so I can save on the central HVAC Propane costs.
Your Advice is greatly appreciated.
Questions:
