Oooo got you! I would try and fix it right now but that pipe is hot ahhahaha I’ll do that tomorrow thank you! Should be ok though?I normally put the level on the vertical face to level it vertically. Assuming what you did is fine though..?
To me level side to side (pivot pin exactly at 3 and 9 o'clock) is more important than the vertical of the tee being dead nuts vertical
That 200 is fine...the other 2 maybe 110 off/140 on? Dunno...probably just need to play around with it and see what works well...Read three articles and all different options any suggestions on my limit switch settings
right now 115/150/200
What's it read?Stove pipe isn’t bad should be alittle hotter temp wise with magnetic temp guage
Perfect...250* (242) externally means almost 500* internally...and that's plenty!Just under 250
Oh...wait, that's a probe type themometer? If so then yeah...a little low.
You could try to bump up to -.05"...or is there some sort of damper adjustment on the furnace?
I also have a prob style but it says only for double wall pipesit’s a single wall pipe so I am using the condae magnetic pipe thermometer
Those temps are good then.it’s a single wall pipe so I am using the condae magnetic pipe thermometer
moved it to that settings
the whole wood stove is acting different now
-stove is actually getting hot outside is about 500 degrees with laser thermometer
-Stove pipe isn’t bad should be alittle hotter temp wise with magnetic temp guage
hot air is actually blowing thru the vents
only concern right now is stove getting close to 500 degree may be fine but haven’t seen it actually get that hot
also nanometer is almost perfectView attachment 274165
I can do that with going down to merv 4 filtersI'm not a furnace guy but I wouldn't have expected the furnace to get much hotter by getting draft under control? Might have to check out static pressures etc in your duct system? Almost sounds like you need more air moving through it now. I'll duck out again now.
You already dropped from 11 to what, 6?I can do that with going down to merv 4 filters
Seems way better!! The soon to be baby’s room was 67 while the house was 70 that’s the best it’s been yetYou already dropped from 11 to what, 6?
So what's your findings after running a load or 2 through 'er?
So maybe 4 will get it 1 degree more We use essential cookies to make this site work, and optional cookies to enhance your experience.
