Stove has been idle. It went through start-up normally and I noticed the top auger was not feeding. I removed motor and tested and found it turns with direct voltage applied. I did a master reset (F5) also the other reset where you scroll through each function (all appear to work) Checked vac. lines and also tried to start with vac switches jumped. Tried resetting several times. Now when I attempt to start it goes into E-2 code within a few seconds. Dont know if I made a simple problem a bigger one by doing all the resets?
![[Hearth.com] Englander 25-pdvc problem [Hearth.com] Englander 25-pdvc problem](https://www.hearth.com/talk/data/attachments/223/223660-f244d20ab01679843a320452354c236a.jpg?hash=vM6TJySXeo)
![[Hearth.com] Englander 25-pdvc problem [Hearth.com] Englander 25-pdvc problem](https://www.hearth.com/talk/data/attachments/223/223664-e8748a1ec28b241a38ca44e9f968645f.jpg?hash=1Ac4VD_yY9)
