I have put together some mini kilns to season some of my wood faster. I have a friend that is in need of wood so Im helping him out. I put this together on October 2nd, obviously the sun angle is getting low so high heat temperature are not expected. It was a high of 70 degrees and the inside kiln temperature was 114... Not bad. Today november 24 it is 43 degrees the sun angle is alot lower and the inside wood temperature by my IR gun says the wood was 86 degrees. I believe that you can season wood fairly quickly with smaller kilns over the course of the fall, winter and spring. I dont think that the larger ones I have done in the past would be this warm.
The mini kiln is just a pallet with wood stacked on it. This kiln is exactly half a cord, 4x4x4. It is up off the ground higher then the other kilns. This is on 6x6 RR ties. The sides are wrapped with contractors stretch wrap, plastic put over top. The plastic was put on with the center being 14 inches high in the center and 2 small u shaped vents cut open. More wrap was put around the plastic to hold it in place. Im going to do a test split tomorrow to see how its going. I did test the wood prior to stack and the wood was in the low to mid 30s.. hers some pics
![[Hearth.com] Fall/winter seasoning in Mini kilns [Hearth.com] Fall/winter seasoning in Mini kilns](https://www.hearth.com/talk/data/attachments/286/286287-5e0c46d6faae26a314a7f12740988108.jpg?hash=mzQOvPTRVr)
![[Hearth.com] Fall/winter seasoning in Mini kilns [Hearth.com] Fall/winter seasoning in Mini kilns](https://www.hearth.com/talk/data/attachments/286/286307-143e35dbfc10e2447e49f1a7274c552a.jpg?hash=CPaeJrX3i-)
![[Hearth.com] Fall/winter seasoning in Mini kilns [Hearth.com] Fall/winter seasoning in Mini kilns](https://www.hearth.com/talk/data/attachments/286/286308-f17030ed9f81b07f864b533bd88901b6.jpg?hash=RKWN2uPckE)
![[Hearth.com] Fall/winter seasoning in Mini kilns [Hearth.com] Fall/winter seasoning in Mini kilns](https://www.hearth.com/talk/data/attachments/286/286320-d51af6a3bd223ab523d0ed3426429920.jpg?hash=r4FJsX4SCy)
![[Hearth.com] Fall/winter seasoning in Mini kilns [Hearth.com] Fall/winter seasoning in Mini kilns](https://www.hearth.com/talk/data/attachments/286/286541-28d0c567f4c4845741216874afc377ce.jpg?hash=Glb0QTqt2C)
![[Hearth.com] Fall/winter seasoning in Mini kilns [Hearth.com] Fall/winter seasoning in Mini kilns](https://www.hearth.com/talk/data/attachments/289/289061-a3ff92061fc4072a9ce5f1b98583e94a.jpg?hash=-tn96bUhM-)
