I aplologize if this has been already discussed, however, I was unable to find an answer by searching.
I am currently running a Jotul F55 to heat my 1500 square foot, moderately insulated home. When I made the purchase I wanted a stove that would potentially run, or at least keep my house warm, for 12 hours. Well the stove is performing as expected during the deep months of winter. At the end of the burn cycle the house temps are about 67 degrees or so and at the peak of a reload, about 74 or so. This is exactly what I would like, however, as soon as the temps outside begin to rise, so do the house temps. At the end of a burn cycle, the house will be about 70 degrees, putting my reload temps at about 77 degrees. This is too much and I must let the stove go out and am relighting fires rather frequently.
I am by no means unhappy, but I have someone willing to take the stove off my hands for pretty much what I paid for it (got a pretty good deal). The stove would be replaced with a Fireview. I would then be able to keep the stove running longer. My question is what temps will a Fireview maintain if reloads are stretched out to nearly 12 hours. The numbers I am hoping to hear are home size, outside temps, inside starting temps, inside temps after 12 hrs. I understand this may not be how you folks run your stoves so feel free to explain how you run your stove. My instincts tell me I should leave well enough alone, but who can resist the opportunity to get a new stove.
Thanks in advance,
Dutch
Thanks in advance,
Dutch
