Wood smoke is not going to help that. Something to consider if there are neighbors.You have to avoid the pollution tho by staying in hills outside cities, the mountains trap in the smog and thermal inversion is nasty.
The 17VL was invented by a Hearth.com member and introduced on Hearth.com. Here is some discussion on it.So the 17VL is as rated? I may try
Let’s remember our high-school physics:I see that the Englander 17VE is rated for twice the BTU's than the F100 despite having the same size firebox.... can that be?
BTUout = BTUin x efficiency
Your firebox size and wood species dictate BTUin, and the stove dictates efficiency. The efficiency of stoves vary, but more so between technologies than within them. In other words, most tube stoves will have similar efficiencies, at least close enough that it’s not going to cause one to rate double the other.
BTU is a unit of energy, like kWh, and BTU/hr is a unit of power (= 0.293 watts). You can trade BTU/hr for burn time, and so it’s likely when you see huge discrepancies in BTU/hr ratings between two stoves of similar size, they were collected at different burn rates.[/QUOTE
Makes sense. Thanks
https://www.hearth.com/talk/threads/englander-17-vl-wood-storage-under-stove-bad-idea.57341/
2 season review
https://www.hearth.com/talk/threads/controlling-a-wood-stove.82933/
The method for cleaning varies with the stove. One option would be to put a telescoping piece of stovepipe connecting the stove. That will allow one to lift off the pipe easily and it also makes installation easier. BrotherBart had an F100 and may have some tips on cleaning methods.A friend of mine warns me that if I go straight up thru roof w/o an elbow or clean out tee I am going to have problems in just a few months... I looked on this site and read that I will have to clean baffle boards and blanket - is that correct and is it difficult?
Your friend is not correct. Straight up is the best for draft and keeping the flue cleaner. What will affect how cleanly the stove burns is the dryness of the wood and how the stove is operated. If you have 17' from stovetop to chimney cap that should be ok. Try it before extending the chimney pipe.
No baffle boards and blanket in the F100. Just the cast iron baffle that you lift up and drop into the firebox for cleaning. Straight up is definitely best for draft and pipe cleaning. Mine was in the basement so I had to vent into an elbow into a liner in the tile chimney. A pain in numerous body parts to clean the chimney and pipe.Straight up would have been wonderful.
- by you folks, am leaving town in a few days and will finally be installing stove in Oaxaca, Mexico.We use essential cookies to make this site work, and optional cookies to enhance your experience.
