Not quite sure if I am asking a valid question but I am wondering what people are seeing for flue gas temps with their gasification boilers? I have a 2.5+ story chimney that gets a low draft (based on Manometer) but also generating a high flue gas temp. 250C+, the boilers upper limit was set at 250C so the software was controlling the burn. I have recently increased the upper limit to get a sense of where it wants to go but Murphy's Law. I am now in a part of my wood pile that is made up of a different wood and it has gotten much colder - not sure of what caused it but I am now staying under 240C. The wood that was causing the hign flue gas temp is super dry (3+ years for the most part). The boiler has a 180mm (just of 7" diameter) exhaust and I feed it into 8" stovepipe that feeds into a clay lined flue that has outer diameter of 7.5x11 (wondering if a liner is needed). Having the chimney cleaned tomorrow to be be sure I know what I am working with but I think it is clear. Thought I would check to see what others are seeing out there.
flue temp - a condensing gasifier, of all things.
