thank you, the plan is to finish it off with antique beams to match the sealing beams.... one day.....lol
According to hearthstone the flag stone will be good for your hearth protection I had concerns about building my hearth pad and wrote them this was their reply
"Unless the stove is installed into an alcove, the hearth (floor protection) does not require a specified R-value. The backer board will provide the ember protection that is required, as long as it is a continuous section that meets the minimum dimensions of the hearth (see the attachment from the test lab).
Jim Casavant
HearthStone Quality Home Heating Products
Technical Support
Phone 802-888-5232 Extension: 225
Fax 802-888-7249"
elkimmeg said:You know if he claims to never to use the door, I could accept that if it was welded shut. I can not sit in his home and monitor his usage 24/7
as an inspector I have to assume a door can get used ,unless permanantly fixed so that it can not be opened. Really that's not a hard a** approach. Everyone knows the requirement and if one reads their manual ,then it is pretty hard to miss it. Then again if one read their manual,they would have seen the requirement of permitting and inspections
So Ny soapestone are you advocating blatant scoffing of code and installations according to the listings? OR are you advocating only following what suits your situation.
Are you recomending other to follow your advice, to only apply what suits them? I'm sorry NFPA211 has no NY Saoapestone exceptions that I have read.
I pointed what all other here also saw. Lack of proper clearance to the loading door and it is not even close. Nothing you said makes it any less non compliant.
Generally I agree with most of your post and respect your knowledge but this time you crossed a line . You would have been better not responding, than advocating scoffing code.
I think I do a decent job of providing a degree of safety while inspecting. Your post just underminded all, that I have been trying to bring forward, in respect to proper stove installation safety
elkimmeg said:there are places in the code where a wondow to close to an exhaust vent can be made inoperatable to satisfy code such as screwing the sash so they can not be opened
I have not requested UL approval to screw the sash.
All of this is a moot point the stove was never permitted or inspected that alone violates the listing at this point he has chosen to arbiturarly to pick and choose what part of the listing if any he used to installation compliance. Without a permit again a moot point the stove should not be there in the first place.
Second if he really had and issue he could have purchased a Jotul Black Bear and installed as such that the clearance infront of the door is a none issue
That like saying geez officer I'm mark Martin It ok for me to speed in that zone I'm trained to drive at these speeds.
You could still get a ticket and you know that every time you do 60 in a 55... but a lot of officers will use their discretion and not pull you over in that scenario.Another part of your arguement is you engineering disipline appicapable to code issues Would you please sign off this guys installation in lew of code and cornirm no danger exist and that the door will never be uses. If you are not then your are even more guilty of advocating what has been tested and listed no different my welding or permantly making the door inorperable id a valid request.
If you tell me you will never use the door what about the wife guest children the next owner are you willing to record it in a deed restriction
This is a ridic arguement you can not certify this non permitted non code compliant setup any more that I can pass it. Lets move on
He had choices he did not make as such the Jotul installation The code enforcement official could demand the stove removal No ticket no laundry No permit
He came here and now it was pointed out he has a non compliant installation. Its not in my jusisdiction. I do not have to deal with it
BTW I agree with the height consideration of adding to a safety margine but sparks glowing embers do fall to combustiable surfaces below..
