hughmyster said:
Derek said:
hughmyster, I don't have any trouble with "backpuffing" at all. I do however always open the air control and damper all the way before opening the doors. I also open the doors slowly. The only time I have ever had smoke roll back into the house is when the doors were opened quickly. The movement of the doors creates a draft stronger than the draft from the chimney for a brief second allowing the smoke to roll out of the box. I really don't think drilling holes in the plate is going to help much with this matter. And the downside would be that you would lose the ability to choke down the fire for a long burn or to get it back under control if it started to climb to extremely hight temps. I could be wrong but I would strongly advise against that plan. It is my understanding that backpuffing with a hot stove would almost have to be caused by negative pressure in the house (assujing the chimney isnt' clogged). Try opening the window closest to the insert for a minute before you open the doors and see if that solves the problem. In new construction homes that are built air tight it doesn't take much to cause negative pressure. Exhaust vents like the ones above your oven and in the bathrooms are enough to create this negative pressure situation.
I also open the doors slowly when reloading. When i say backpuffing i mean when i close the air control all the way down the wood gasifies and have mini explosions causing smoke to be pushed out the door seals. My chimney is 30 feet tall. The smaller the splits the more backpuffing i get. Does anyone else see this?
Try removing the CAT and cleaning it as well as the "box" it sits in. I have a 36 & had the exact problem you described earlier this season & after a good cleaning it has been fine. Sometimes fly ash is easy to see on the CAT but in my case it was deeper in the honeycomb & not real noticeable until removed, it doesn't take much blockage to disrupt your air flow....I'd say mine was maybe 10% blocked at the most.
Also I mention cleaning the "box", more specifically once the cat is removed you'll notice a channel on the bottom right & left sides of the box, mine was filled with ash as well thus further resticting air flow. I think what was happening in my case (and probably in yours as well) is that during the mini "explosions" the gases in the firebox expand rapidly & were being pushed out the seals due to the restricted flow through & behind the CAT....through being the fly ash in the CAT itself & behind being the channels I described. When you remove the CAT you'll see there's a steel plate behind it that is not quite as wide as the box itself so the gasses must flow around the sides & also through the two channels.
Anyway try the above & see if it solves the problem...........this is my 5th season with this unit & although I clean the CAT at least once per season I had never had as much ash accumulation in the CAT as this time & really couldn't see it until I removed the CAT. Now I can turn the air down all the way, still get the mini explosions (this is normal with air cut back 100% & a good hot firebox) but no back puffing anymore.
