Chilly day and I figured it was time for first fire of the season and I'd give it a go with gel starter for the first time to see how it would go........Didn't go as well as I thought it would.
The stove is a Harman XXV and I went by the book as described in the XXV user manual (excerpt below). Used Rutland One Match starter gel.
Igniter Switch to "MANUAL " (up position)
Make sure the unit is plugged into a 120 VAC,
60 HZ electrical source. The power light should be
the only light lit.
To avoid unwanted smoke, be sure there is no
fuel in the ash pan prior to lighting.
1. Turn FEED ADJUSTER to desired feed rate.
No. 4 is good for most pellets.4
2. Turn the Mode Selector to “OFF” and
then to the desired mode. This will reset control
and start the combustion motor.
3. Turn the Temperature Dial to the desired
setting.
4. Clean burn pot with scraper if necessary.5
5. Fill burn pot with pellets, only level with front
edge. (Do Not Over Fill).
6. Add starting gel on top of the pellets. Stir gel
into pellets for fast lighting.
7. Light starting gel with a match, and close the
door. Operation will begin when the fire reaches
the proper temperature.3
8. Fill hopper with pellets and remove ashes
as required.1, 6
Dribbled about a tablespoon or more of gel over pellets in burn pot stirred the pellets a bit, and lit it. Nice blue flame on top, but wasn't getting down into the pellets. With combustion fan running it "fanned" the flame and threw a few sparks, but the flame didn't want to seem to burn down into the pellets below and the combustion fan appeared to make it worse. Added a bit more gel on top, but didn't seem to help. A hit with the propane torch wasn't much better. The torch scorched the pellets, but no joy of flames. I rather thought pellets might ignite easier.
Out of frustration just to get stove going I put the stove to AUTO, used the ignitor, and it started no problem in a few minutes as usual.
Any ideas or hints that might help getting the stove going in manual with gel or what kind of problem I was having?
the only light lit.
setting.
as required.1, 6
. Got the stove going this morning with just the gel. The Harman instructions stated to only put the gel on top of the pellets, where the gel starter instructions stated put a tablespoon in the burn pot and then some on top of the pellets. I think having the gel under the pellets helped as the gel would burn up through the pellets, rather than just on top. Leaving the door open as a few suggested until the pellets got going helped quite a bit also. I'll be using the ignitor for most starts, but at least I now have an alternate way to get fire if the ignitor goes "kablooie". Probably give the torch a try again in the next week.![[Hearth.com] Gel Starting a Pellet Stove? [Hearth.com] Gel Starting a Pellet Stove?](https://www.hearth.com/talk/data/attachments/143/143177-365da2b678e4b3e93c25f7e24fbc5f4f.jpg?hash=LGz4kittH-)
![[Hearth.com] Gel Starting a Pellet Stove? [Hearth.com] Gel Starting a Pellet Stove?](https://www.hearth.com/talk/data/attachments/143/143226-b9aa4cda6e3d70189dd26c5320a18935.jpg?hash=c0A40AK7E5)
![[Hearth.com] Gel Starting a Pellet Stove? [Hearth.com] Gel Starting a Pellet Stove?](https://www.hearth.com/talk/data/attachments/143/143227-9ce131d8d699e70d4f16aea18c016100.jpg?hash=Z65NVj4VuN)
![[Hearth.com] Gel Starting a Pellet Stove? [Hearth.com] Gel Starting a Pellet Stove?](https://www.hearth.com/talk/data/attachments/143/143228-aaaadb10b3b493a0fd198ca60412a419.jpg?hash=oGj6xoFONP)
![[Hearth.com] Gel Starting a Pellet Stove? [Hearth.com] Gel Starting a Pellet Stove?](https://www.hearth.com/talk/data/attachments/143/143229-f0882ab91f87f2283eb35cfbc3430901.jpg?hash=1ezMQCz6L6)
